Aluminum 454 Build
Old Oct 17, 2013 | 12:49 PM
  #221
LPE 403's Avatar
Originally Posted by Briou
I am about ready to order an oil pump...anyone have any suggestions? I don't know if I should get the melling high pressure, or the high pressure/high volume...does someone make a high volume/stock pressure? Really just unsure of what I need....
Melling #10296...
Old Oct 17, 2013 | 01:28 PM
  #222
RAMPANT's Avatar
I went with a SLP high pressure which if memory serves is the 295 Melling, but machined for a double roller chain.
http://www.ls1gto.com/forums/showthread.php?p=4141523
Old Oct 17, 2013 | 01:46 PM
  #223
Briou's Avatar
So that is the high pressure/high volume pump correct LPE? Is that what you went with on your build?
Old Oct 17, 2013 | 02:13 PM
  #224
96lt4c4's Avatar
Melling 10296, blue spring.
Chain
http://www.briantooleyracing.com/iwi...lications.html
I ran the stock GM cam and crank gears.
Old Oct 17, 2013 | 02:39 PM
  #225
Briou's Avatar
I think I am going to go with the hex-a-just timing set....
Old Oct 17, 2013 | 03:24 PM
  #226
Gray86hatch's Avatar
Call Tim at the Car Shop Inc
I am using the pump that he sells and it has some features that no one else offers
These big stroke alum block engines need all the help they can get in the oiling area.
Tim
Old Oct 17, 2013 | 05:44 PM
  #227
Briou's Avatar
Is this the site? They have a whole pile of pumps on the site...guess a call is in fact in order
Old Oct 17, 2013 | 07:51 PM
  #228
Call Tim he will get you the correct one for your engine.
Tim
Old Oct 20, 2013 | 10:11 PM
  #229
Briou's Avatar
Got home this weekend and got a chance to test fit the new oil pan, and get the headers fitting....These headers are huge!!!!
The fat I had to trim off the trans...
and the new oil pan...it has some clearance issues with the tie rods but I think I can get that straightened out with some shaving....
Old Oct 29, 2013 | 10:32 AM
  #230
Briou's Avatar
So I've run into an issue with the power steering system and the idea of a hydraboost brake system...the directions for the billet specialties tru track power steering pump clearly state that the system is not designed for use with a hydraboost brake system...so now I am trying to figure out what to do about brakes...I would like to stay away from a manual system....does anyone make an electric vacuum pump I can run to the stock brake booster?
Old Oct 29, 2013 | 10:36 AM
  #231
Don't run that front dress get the holley brackets and use a corvette pump.
Old Oct 29, 2013 | 10:41 AM
  #232
Briou's Avatar
I am going to run the billet specialties kit either way...I already have the kit and it takes some other headaches out of the equation...I am also thinking of using a vacuum manifold block of some sort coming off of the vacuum rails of the intake to distribute vacuum to the brake booster and the map sensor....I just emailed Billet specialties so we will see what they have to say about modifying this system to work with hydroboost.....
Old Oct 29, 2013 | 06:19 PM
  #233
lil john's Avatar
Jeg's sells the vacuum pump for your brake system had mine since 05.
Old Oct 29, 2013 | 06:51 PM
  #234
Briou's Avatar
How do you like it? Work well? I was looking at them earlier and it looks like they are meant for picking up slack at idle with a big cam, and not really to run 100% of the time....is that the case?
Old Oct 29, 2013 | 07:06 PM
  #235
Briou's Avatar
I think I just found the answer to my problem.... http://www.abspowerbrake.com/ehpm.html
Old Oct 29, 2013 | 07:19 PM
  #236
LPE 403's Avatar
You're not going to want to share vacuum between MAP and the brake booster due to the possibility of screwin up MAP readings. Call Kinsler....
Old Oct 29, 2013 | 07:28 PM
  #237
Briou's Avatar
That is what I was afraid of....you have any experience with the ABS Electric brake boost system I posted?
Old Oct 29, 2013 | 07:34 PM
  #238
LPE 403's Avatar
I run a Hydratech hydroboost....all hydraulic while maintaining my ABS. I would definately check those guys out. Talk to Paul
Old Oct 29, 2013 | 08:10 PM
  #239
Briou's Avatar
Yeah I have looked into the hydroboost systems, I just can't run them with my power steering system...I am looking at the electric boost system made by ABS
Old Oct 29, 2013 | 08:12 PM
  #240
lil john's Avatar
Sorry about that....Yeah it helped a lot when at idle and stop light braking with the ole 383 setup... I'm on pause for now until after new yr. I've gotten most of the things I wanted to end this yr. I got my Comp cam 1.8 adj stud mounted rockers(great bargain for solid roller set-up) I've been on the road most of the time the last 2 months doing the Stone Remodels as usual. I could always read all of the post but writing or typing on the Xbox is something I hated doing in the hotel room. Hydratech hydroboost is the best thing out there i personally would not want to run a Elec. booster what happens when there is a short...
Murphy's law 101: is typically stated as: "Anything that can go wrong, will go wrong".
Now I'm on the aspect of handling on the G-body Malibu wanted is 265-275/18 fr and 305-315/18 rear.
Keep @ it B.
