is this a good cam for nos
Old 06-26-2013 | 12:00 AM
chevyrunner's Avatar
Default is this a good cam for nos
Have a forged 415 stroker high compression (6.0 iron block)
running a 251/267 624/624 115 lsa cam
looking to run a 175-225 shot... Will this cam respond well with this much nitrous?
Thanks guys
Old 06-26-2013 | 12:52 PM
Gunslinger09's Avatar
I would think it would work well.
Old 06-26-2013 | 05:24 PM
SNLPerformance's Avatar
How much compression is high? What's the rest of the set up ie intake, heads, exhaust? A cam that works well NA will work well with nitrous...it just may need a little help on the exhaust side with more duration to help clear the cylinders is all.
Old 06-26-2013 | 06:59 PM
Blackpanther99's Avatar
For a medium size shot it should work good IMO.
150-200shot. Im no expert but thats what I think.
Old 06-26-2013 | 07:51 PM
ramairws6's Avatar
Yes...........
Old 06-27-2013 | 12:04 AM
compression over 13:1, fast/fast, ls3 cnc heads, dual exhaust with x pipe, 1 7/8 headers
its my new set up motor just went in the car.. ive never had a cam with a lsa of 115 always been 112-113 how will the 115 lsa effect this ??
Old 06-27-2013 | 03:48 PM
Sounds like a good choice then, as it broadens the power band. The late IVC was what I was mainly worried about, but with 13:1 you'll be fine. Should be a screamer, good luck.
