Unknown miss! Please help
Old Aug 1, 2013 | 11:46 AM
Bad28's Avatar
Default Unknown miss! Please help
Ok I have a 370 with 823 heads and and l92 intake fully bolted I just installed this into my 2005 Chevy Swb I'm having a miss and can not for the life of me figure out what's causing it It's got a mis at pretty much all of part throttle but not at wide open. I've replaced cam sensor, crank sensor, all 8 coils, wires, spark plugs, maf, map, o2s, took laptop tried to turn **** off and mess with stuff checked timing gear all please any help would be appreciated
Old Aug 1, 2013 | 01:33 PM
87silverbullet's Avatar
Well, I can tell you have went about it wrong in replacing all those parts that weren't needed.
You need somebody to powerbrake the truck and make it miss. Then pull each coil wire to see which cylinder is misfiring. Then find out what that cylinder is missing to make it mis-fire. The motor needs fuel, spark, and compression to fire. So then you can go from there to find what that cylinder doesn't have.
Old Aug 1, 2013 | 02:53 PM
Bad28's Avatar
That's normally how I would attempt to solve this but it does not miss at wot it's random which is making it even more difficult it's not the same cylinder and its inconsistent sometimes it's 1 cylinder sometimes it's 2-3
Old Aug 1, 2013 | 04:27 PM
Sounds like the cam is off a tooth.
