L92 Valve upgrade needed with LS9 Springs and small cam?
Guys,
Do I need to upgrade to some Manley 11620-8's and 11621-8's to safely run LS9 springs and a small cam with only 210/218 @ .050 and .500/.500 lift?
I won't be running the engine up over 5,000 very much, but there will be times when I stomp it and want it to go to 6,300 or 6,500......
I am trying to build a 425hp+ at the crank LY6 engine with some milled heads and an attempt at 10.25:1 compression also; This is going into a truck that I hope to get 150,000 + trouble free miles on....
I have been reading back and forth stories about L92 Valves breaking, LS3 valves breaking, etc....
I can't afford the titanium/inconel LS9 valves, nor do I want the guide problems that some has seen with these valveguides required to run Ti valves.....
Opinions?
And yes, I am going to degree the cam, use the phase limiter, etc., and check for PTV clearance.....
Opinions?
Sure, I understand the weight of the L92 solid valve is heavier than the LS3, but, my main concern is if the LS9 spring will control bounce or float with such a small cam because the LS9 spring was designed to control a much lighter Ti intake valve and Inconel exhaust valve.....
I can't find the installed Seat or open pressure of the stock L92 valvesprings or the LS9's.....
I don't mind buying expensive parts, I just don't want to buy a monster set of springs for such a mild cam and have the springs be wore out in 30,000 miles, thus, I was looking at OEM parts ...
ok, so, looking at springs for the long life of the engine.....
Best choices for a small cam with .499 lift and 210/218 @ .050 ?
PSI 1511ML?
PAC 1518?
PAC 1218?
Patriot gold?
PSI 1511ML?
PAC 1518?
PAC 1218?
Patriot gold?
Sorry, forgot to mention that it is a VVT grind cam, so I will be using the comp cams phase limiter kit and keeping VVT, so not running too much spring pressure is important to keep from over running the hydraulic VVT system
