Need some advice on my first LS shortblock
Old Sep 5, 2013 | 03:57 PM
filmjay's Avatar
TSP do cores? Or any other reputable builders offer core swap?
Old Sep 6, 2013 | 03:56 AM
lil john's Avatar
Most will sell you the engine out right....LME here in Houston has great deals also..4500 for LS2 408
Old Sep 6, 2013 | 04:03 AM
lil john's Avatar
I'll take the block off of your hands.....How much, make me a deal I can't refuse, I'm looking for a aluminum block to send off to ERL...... I have a lot of irons in the fire,I can put stuff on hold..... I need a aluminum block for a crank I had did months ago 4.175 stroker....Thread was called: Will SBC rods work?
Old Sep 6, 2013 | 09:47 AM
filmjay's Avatar
I don't want to buy one outright. I know I can do that, everybody sells outright. And why would I sell you my core block when that's why I need to core my block?
I wouldn't mind some of whatever you're smoking...
lol
Old Sep 6, 2013 | 11:16 AM
LivernoisMotorsports's Avatar
What shortblock do you have to turn in as a core? What engine are you looking at going with?
Old Sep 6, 2013 | 12:35 PM
Oh4GTO's Avatar
You would get a lot more money out of your assembled shortblock rather then just use it as a core with the stock rotating assembly going to waste.
Old Sep 6, 2013 | 02:10 PM
filmjay's Avatar
I have an stock bottom LS3 (08 C6). Looking at doing a semi-daily driven n/a, bolt-on LS3 416 (with an A6 and stock converter, but use paddle/manual mode exclusively). I'm trying to decide if I should use my block or do a core swap.
A lifter collapsed and shaved the cam lobe down pretty well. #8 intake lifter bore has a very fine scratch in the wall. I don't know if it's something that would need sleeved or not. Lots of glitter in the pan, but don't know if it's anything else but cam lobe shavings. Don't know if the bearings got trashed...haven't pulled the block totally out yet.
Everything else looks good.
I'll need short block (or rotating assembly), lifters, oil pump and a cam...plus all associated gaskets/seals/bolts. I have everything else and is in good shape. (7.4 hardened pushrods, new dual .675 springs, etc...)
Was eyeballing one of your "mini stroker" 388's when I was keeping the blower. But with the blower setup for sale, I opting for adding inches to make up for some of what I'm losing. I want 500+ and don't think I'll have much trouble getting there with what I've got on a 416.
Only concern....budget.
Old Sep 6, 2013 | 02:13 PM
filmjay's Avatar
I don't have time to find a seller...selling this ECS blower setup has been a pain in the butt unless I just want to give it away or trade some of these jokers for their leftovers. Nor do I have the extra space to store it til then. All work is being done without a garage, on jack stands. And with the block having some potential mild damage, I wouldn't get much more than what I'd get for a core relative to the added hassle.
