Need some advice on my first LS shortblock
Old Sep 2, 2013 | 07:24 AM
filmjay's Avatar
Default Need some advice on my first LS shortblock
Hi guys. I'm putting together my first LS short block, and while ordering parts, came across a few questions....
First, reply knowing that this is NOT a 1,000 HP race car build. I had a blower, but am now going back n/a...with a budget stroker. This will be primarily a stout driver/road trip car. Not looking to burn up the track with this car anymore....may do a few passes or a track day just to benchmark, but that's it. Thought about a baby shot later down the road (less than 150-200), but that depends on what I put together now....but I know I'll always have that itch. Lol.
So, here goes...
The ever present...416 or 427 debate. No FI, so why not 427? Decided on a 4.070 bore, so not worried about the cylinder walls as much...but am concerned with the long stroke and losing ring seal. Any advice?
-Callies/Lunati/K1/Scat/Eagle? In my SBC days, everybody seemed to run Scat or Eagle. In the LS world, Callie's seems like the go-to. Lunati and K1 seem to have some nice LS pieces too.
Some shops..TSP and Livernois for example, have their own budget crank and rods...are they any good? Remember...baby shot later on, maybe...unless I can get enough out of it to be happy on all motor.
-Tool steel wrist pins...do I really need them at my level?
-Coated bearings/skirts...again, do I really need them at my level?
-Balancing....should I have the rotating assembly balanced from the vendor? Or at my machine shop with the block? Same price either way.
-Head gaskets...thinner now to bump CR slightly? Would limit NO2 useage in the future, but if the n/a numbers are good enough I wouldn't even bother and just turn my attentions and future budget elsewhere on the drive train.
That's all for now...I'm sure I'll think of something else though. Lol.
Thanks for any info advice.
Old Sep 2, 2013 | 07:37 AM
86Z28USAF's Avatar
I ran into this question a while ago. I was thinking of doing a 427 LS3 but i was steered away from it due to skirt wear issues dont feel like dealing with higher maintanence since my application is similar to yours. so i ordered a 418 from TSP. And from what ive been told their budget stuff is pretty solid. I went with Callies crank and Rods just off reviews from others.
Old Sep 2, 2013 | 07:53 AM
Gunslinger09's Avatar
I would do a 418 if you are set on the stock bores. They seem to hold up much better than the overly long stroke motors.
Old Sep 2, 2013 | 08:46 AM
BOLO's Avatar
How did you guys come up with 418 cid? 4.100 stroke/4.030 bore? Or is it 4.000 stroke/4.070 bore?
If my calculation is correct, a 4.100 stroke/4.070 bore would take it close to 427cid.
Old Sep 2, 2013 | 08:56 AM
87silverbullet's Avatar
LS3/L92 blocks already come 4.065 bore and if you go with a 4.000 crank and a 4.070 bore you get 416. If you go 4.080 bore you get 418 cu in.
Old Sep 2, 2013 | 09:04 AM
All responses in bold
So, here goes...
Go with a 416 with the 4.000 crank. You won't miss the 11 cubes and your motor will have better ring seal.
If you are going to throw a shot on it then again, stay with the 416 setup
Nah they aren't needed
Nah they aren't needed either.
I would just let whoever you buy it from just balance it before you get it
I would go with a .040 gasket that way your compression will be 11.3-4 with the -3 cc L92 pistons TSP or most manufacturers have. That compression will still be fine for nitrous.
Old Sep 3, 2013 | 11:32 AM
filmjay's Avatar
Thanks for the replies.
I figure I'm just going to stick with the 416 route, especially since I'm keeping my stock ported heads/intake.
Still debating on what the bottom end should be...house TSP stuff, Callies, or Lunati.
Old Sep 3, 2013 | 11:34 AM
86Z28USAF's Avatar
depends on wether you want to spend a couple extra bucks or not
86Z28USAF's Avatar
the tsp stuff should be just fine
Old Sep 3, 2013 | 11:46 AM
filmjay's Avatar
Not unnecessarily.
Old Sep 3, 2013 | 01:10 PM
filmjay's Avatar
Going to have to have a lifter bore sleeved if I use my block. With the added cleaning and machining, I'm wondering if it'd be cheaper to simply get a new short block and just use mine as a core....
Old Sep 3, 2013 | 01:38 PM
86Z28USAF's Avatar
yea you might be just payin for the name like i said i heard the tsp brand was solid but thats just what i heard i personally went with callies
Old Sep 3, 2013 | 04:52 PM
Since you are going to be on the motor more often, I would just go with a Compstar crank and rods and use Wiseco pistons. You will have a good crank and rods for a cheap price.
Old Sep 5, 2013 | 10:19 AM
filmjay's Avatar
Anybody got any ballpark machining prices?
sleeve lifter bore
hot tank/clean block
standard stroker machine work, bore/hone, new bearings pressed, etc...
or just get a short block and core mine?
Old Sep 5, 2013 | 02:05 PM
lil john's Avatar
sleeve lifter bore=350 to 450
hot tank/clean block= 100 to 125
standard stroker machine work, bore/hone, new bearings pressed, etc...=600 to 700
And don't forget you have to get it Balanced.
Old Sep 5, 2013 | 02:37 PM
LS1MCSS's Avatar
Just call up TSP and order their 418 short block and be done with it.
Old Sep 5, 2013 | 02:51 PM
lil john's Avatar
U would do better buying a short or long block 416...I just like to see every thing as I build ....My engine is very similar to yours, except for LQ9 and it being a 408.To have your block complete with all of your own parts will set u back @ min.$1500.oo and you will have to have all your OWN parts....Rods 600/Crank 750-800 all eagle.Pistons 750+..... bearings, rings=Total seal..150 to 250 depending..... and then pay 1500 for assembly and balancing.Also ARP studs+ 200..... block work is included in the 1500 boring....etc
filmjay's Avatar
That's what it's starting to look like is the path of least resistance. Especially if I can just core mine, and even more so if they can do the wire transfer payment discount. I didn't think TSP did cores anymore.
Old Sep 5, 2013 | 02:54 PM
filmjay's Avatar
Working it out, buying most everything from TSP and using a local'ish SAM machine facility, I think by the time I jumped through all the hoops and gathered all the parts, I may save $100.
If I can core my short block, a new one is the way I'd go.
Old Sep 5, 2013 | 03:25 PM
You're on the right track. It will take longer to piece everything together and get it all assembled. Sometimes I wish I would of gone that route
