Cathedral v.s. Rectangular Port Cylinders - Head To Head
Old Sep 14, 2013 | 02:44 PM
  #41
lil john's Avatar
Well I"ll get u that info...u will have to shrink the valves of the heads or elderbrock LCD canted that a small bore. We watching the game Johnny man. To my haters. Get $ I"m doing everything in my post riding in a 2013 impala.
Old Sep 14, 2013 | 03:43 PM
  #42
Grr's Avatar
Grr
Wow you really think you are something don't you, nobody cares how badass you think you are
Old Sep 14, 2013 | 04:50 PM
  #43
lil john's Avatar
No it's u who is condescending I just learn fast....if u hate then u hate I learned lsx engines in ......? it may have took you longer Y because I've learned from other LSX mistakes.....All engines are the same.....Basic ....That is fact.....Part selection...and Knowledge and Knowing the right People....is what makes true power....
the bore stated was 3.800 i think u meant 3.900 if so read what heads I'm getting Mast small bore heads...Getting Ready for the fight....
Old Sep 14, 2013 | 05:33 PM
  #44
lil john's Avatar
You could also work with a few other heads...it's just research and knowing stuff....off hand you could take AFR/TSP/TFS and if they don't fit get a smaller valve setup.....Port will need to match bore size and don't forget the crank.But Mast 240's are made for 3.900 bore.... look at the architecture & ls3 intake........ I went with a Vic Jr. ...Bare $999.oo it's who you know to get real prices....Fact.
Johnny Foot ball ....+....The Tide =Johnny may have Drowned.
Old Sep 14, 2013 | 05:38 PM
  #45
KCS's Avatar
KCS
Moderator
You get your heads yet or are they still on "layaway"?
Old Sep 14, 2013 | 05:50 PM
  #46
lil john's Avatar
I'm not rich but I do no the owner of the store, so It's to my benefit..2000.oo... they will be gotten as was my cam,lifters,intake,t/b,injectors....etc....
I research things before I spend that's Y I Know a lot...I compare my *** off....
Johnny Football may come back?
Port work will be 1000.oo I have to buy ls7 valves and cut them down to 2.160-.030 Bowl,throat & short-side radius
....This is whats being done....I'm not rich.....I just want what I want....and I'm patient to save to get what I want..
Lay A way starts @....... once begun.....how long will it take if i get a AVG. I do know the Owner, he makes $ while still giving me REAL prices......
Old Sep 14, 2013 | 06:02 PM
  #47
lil john's Avatar
Also I could have sent my L92's off to WCCH........not going to spend twice on heads...Period! they will just sit ....I may lose 179.ea their mine....
Old Sep 14, 2013 | 06:04 PM
  #48
KCS's Avatar
KCS
Moderator
Are you sure the LS7 valves will work? I know Mast/PI/Cary's heads usually require longer or custom length valves, and the LS7's are longer than the other LSx valves, but if you're using custom rockers it may not be much of a problem.
Old Sep 14, 2013 | 06:06 PM
  #49
lil john's Avatar
U guy's enjoy your evening I'm gone
Old Sep 14, 2013 | 06:10 PM
  #50
lil john's Avatar
I see U before I get out of the door yes ...correct on all points...T&D rockers and Maybe a little longer vale set-up....But my head man can do that it's getting them in my hands and saving for the work....Time.... I'm in know rush I want this to be right if this goes right ...I will be able to do other things like the Impala..That's y i got to have my stuff together and Know the right people....to get things done.....In TX....Keep your EYE's open SAT. night
Old Sep 14, 2013 | 06:19 PM
  #51
lil john's Avatar
Just like TFS heads valve is a LS7 valve...Correct?
Old Sep 14, 2013 | 06:30 PM
  #52
KCS's Avatar
KCS
Moderator
I don't think so. Turning the LS3 valves down is a popular option for the TFS heads and they're the same length as the other heads. The LS7's are longer though, so it screws with installed heights and rocker geometry.
Old Sep 14, 2013 | 06:32 PM
  #53
KCS's Avatar
KCS
Moderator
Why did you even choose an LS3 style port? Why not an LS7? You're doing a lot of work and spending a lot of money for what may only be as good as an LS7 head.
Old Sep 14, 2013 | 06:48 PM
  #54
lil john's Avatar
I had L92's since 09 and thought it would be good ...at first...More Hp more money so I got the quickest way there Solid roller...etc..... and I'm not buying heads 2 times to get WCCH to do my heads 900+tax add 1100 and we there...+ a smaller port 267 vs 240 and out flow them...I got intake for L92 setup.....Lets STOP...Mast makes 12 Degree LS3 style port heads that's..... Y...no need for ls7's Mast has LS3's with the same valve lay out......I have thought about changing but I out thought the problem with a EASY answer...Mast 240's
Old Sep 14, 2013 | 06:54 PM
  #55
lil john's Avatar
BTW: I Had 1 of the first sets of TFS LS3 heads ...They were sold to get me here....I have purchase a lot of stuff...cam,injectors,t/b,lifters,Vacuum pump.So now I'm back to heads ...I bought them thinking I'm good but missing parts ...so I still have L92's ...Sold...@ a 200 profit....Now we back to heads I like the idea of a port even smaller than TFS that match their stock # I love to set a mark and try to obtain it/Design or come up with stuff
Old Sep 14, 2013 | 07:20 PM
  #56
KCS's Avatar
KCS
Moderator
So it boils down to port volume and flow numbers? That's how you pick heads?
Old Sep 14, 2013 | 07:35 PM
  #57
lil john's Avatar
? for you KCS...I have a 240cc Mast head that flows 350 @ .700 measured on a 3.90 bore....I change valves from 2.08 to 2.130 min. and match throat/Short-side radius to match increase in valve size......Can I get typically get 20+ cfms on a larger test bore of 4.030...to get over 370 cfm's from a stock style port...you will Need to open it up a tad.........not Can this work...Will this + up....? ......+ equals to add...Tell me Y it will or won't work...
Old Sep 14, 2013 | 07:44 PM
  #58
lil john's Avatar
I chose these heads ....for the fact that. it's a 408..they out flow any Cathedral with a smaller test bore...and similar Runner size.....They have 12 degree valve lay out....... they match my LS3 intake........the port can grow for larger engine size(small thru large bore LS3 12 degree heads.... there may be enough material to port small runner to a large Runner size?..and Last ......Mast makes a good product....
Old Sep 14, 2013 | 07:54 PM
  #59
lil john's Avatar
U asked me all the ?'s will this procedure work?...I have heads in the Lay A Way....Can U help Me ....LOL....Can u tell me Y it won't work...
Here are the true #'s for Mast 240's on a 3.90 bore will this work!?
INCH LIFT INTAKE FLOW (CFM) EXHAUST FLOW (CFM)
0.100 69 105
0.200 37 154
0.300 208 198
0.400 266 217
0.500 306 222
0.600 335 226
0.650 345 229
0.700 351 234
0.750 335 238
Old Sep 14, 2013 | 08:01 PM
  #60
KCS's Avatar
KCS
Moderator
You're grammar is so terrible let me make sure you're asking what I think you're asking. You want to know if I think adding valve diameter from 2.08" to 2.130" and opening up the throat and SSR for the larger valve will get you 370cfm when flow tested on a larger 4.030" bore compared to the 3.90" bore that put down 350cfm @ .700" lift?
If that's the case, I'd say it can certainly hit 370cfm or more on the 4.030" if that is the aim of the guy working on the port. I'd add that I would open the chamber to at least 4.030" of it isn't already. The valve job could hurt or help the numbers, but opening the throat and SS area will help as well as few rousing the valve. There are too many variables to say it will work, but it can work if done properly.
