Weird compression. Lifters or cam?
It's never really run right, and figuring late was better than never I did a compression test on it today and I have 3 (yes, 3) cylinders with 0 compression. 1, 5 and 7 are dead until you loosen up the rocker arm and close the valves, then compression comes back. Into all 3 cylinders. At once.
So, in my mind, the valves seal, the rings seal, the problem must be in the valve train. Right? Lifters junk? It is a gen 4 and when we tore it down to check it out we replaced all of the DOD lifters with used, stock lifters.
Is there a chance it's just the cam? Is there any way I'm getting out of this without pulling the heads? Is it possible I have a minimum of 3 bad stock lifters?
Any thoughts are hugely appreciated....
I'm just gonna take it as an opportunity to put a proper cam in it and do the lifters at the same time, and valve springs. Just replace valve train stuff with new, good parts.
If they're too long, why would I only be having this issue with 3 cylinders? Unless only a few were too long...seems strange...I've got good compression 130-150 psi on all the other cylinders. ****. Think we should switch back to stock pr's?
I don't even have a set anymore, I was told they're the weak link on these engines so I replace 'em whenever I pull one down to check it out.
Thanks for the help so far, keep those suggestions coming!
Its rare but to be safe I check every valve when I do my pushrod length check.
