ls1 to ls3 conversion info
I think I have most of the basics covered but there is a couple of details you'll may be able to help me with.
I have to
-change the sump and pickup to the ls1 front hump style.
-change the reluctor wheel on crank from 58 to 24
-change the injector plugs
-extend the cam sensor wires to reach the timing cover
-extend the knock sensor wires to reach each side of the block
-replace the FBW TB with cable style one
- change the cam wheel to a early ls2 type one now this is where I get a little lost I can only seem to find 3 bolt style cam wheels in that configuration so do I need to change cam aswell or does a company make a single bolt cam wheel with the early ls2 2x configuration as id like to keep the standard camshaft any help would be appreciated thanks.
if you use the box you also don't need to swap the cam sensor.
i am swapping a 58x motor also but i plan on swapping the reluctor, and using ls2 front gear.. don't like the idea of the add on box as i read it adds to the cranking time and its just another thing to go wrong..
Thanks for that wiring info
