New ls3 crate engine popping on deceleration
Old Nov 24, 2013 | 09:41 PM
Cylinder shaker's Avatar
Default New ls3 crate engine popping on deceleration
Just installed a GM crate ls3 (gm harness computer) from jegs into my Nova. Full 2.5 exhaust with h pipe. Rechecked Maf sensor location more than 9" away. This is driving me nutz every time I let off pedal or come to a stop pop pop pop any suggestions to try to lose this? I am not sure what others have done? I have read that there is a way to tune this out but don't and not sure what to try? Someone in a search said there were fuel tables that can be adjusted but again to what? Can this be done with my scan tool? Thanks!
Old Nov 25, 2013 | 11:13 AM
TurboBuick6's Avatar
make sure your TPS is correct voltage with throttle closed. If too high computer will thing your on the throttle and not kick in fuel cut out on decel.
Old Nov 27, 2013 | 08:56 AM
CAMSTER's Avatar
Reduce the diameter of your exhaust tip get a hush muffler or have your tuner disable "decel fuel cut off".
Old Nov 30, 2013 | 10:33 AM
cam's Avatar
cam
Its pretty common, sometimes even between shifts you get a pop. Some cams are worse than others. In a stick car? Drop it into neutral on decel, no popping then. Just a few tips if you dont have access to a tuning suite/tuner
Old Nov 30, 2013 | 03:22 PM
BigEd_72455's Avatar
I get a popping when I have blown out the collector gasket. Any exhaust leaks can cause the popping to some degree. Double check you exhaust system for any leaks at all. If you find some, fix them.
