Durabond CHP-23T cam bearings narrower than OE
Ordered the CHP-23T cam bearings for a 2011 LY6 iron block 6.0 I'm building to go into my TA.
The OEM cam bearings that came out of the motor are wider than the durabond's I installed is this ok. I used red loctite to install them and they went in and the oil holes lined up correctly. The width difference just had me concerned.
