LQ9 + l92 heads + ls3 intake.... And torquer v2 cam ptv issues?
If the heads aren't milled then you should be fine but as you know, it's always best to measure. And a cam costs about the same no matter which one you run really. I'd sell that TV2 and get a cam better suited for LS3 heads. Just my 2 pennies...
I'm with Yonerhottlt1,
L92 heads run best with a cam designed for them. Partick G. and Martin Smallwood @ www.Tickperformance.com can spec you a cam. Both have stellar results.
