416, ported PRC LS3's, going to a carb setup, is it worth it to go solid roller?
I'm wanting to know if it would be worth it to go solid roller or stay hydraulic roller? I know I could spin it higher if need be with the solid but it would be cheaper to keep all the hydraulic stuff.
Plus, while the motor is on the ground in my garage I was thinking of upgrading to a set of PRC 265 small bore LS7's or some RHS ls7 heads. Would that be a better option with a solid roller setup? I was also looking into a Mast intake. To me, a Mast intake probably wouldn't gain much on a ported LS3 head compared to lets say their black label LS3 head but if I switched to and LS7 head, I would see more of again with that head and intake. Let me know what y'all guys think.
You should be able to make 650-680 with the heads you have with the correct cam and a mast 4500 intake.
I am at a crossing point with mine the next step to make more power is a set of mast ls7 and a new intake. This stuff cost about $6500.
I would say stick with the heads you have proper cam and intake and let it eat.
Tim
Tim
By the way, the heads have PRC .650 lift springs
Flow tech induction does my stuff he will be able to set you up with a complete package.
Will be very similar to the stuff I had when I had my 418
Tim
