4.1 bore on an LS3 block?
. This was an endurance type of build making 700+HP. I was under the impression that a light bore cleanup was as far as the block would safely go.Im running a stock displacement LS3 and planned to build a 416-418 down the road when I got bored with the setup. If I can safely go out to 4.100, I will ! If the block will take it, Im a fan of the bigger bore, just for the increased head flow.
What gives? Is it legit?
Travis
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
I have yet to see one of these overbore engines cylinders crack or have major issues. I have seen more failures from poor machine work and tuning that take out even stock standard clearanced blocks.
I remember when folks were saying .030 was about as far as you could go with the 6.0 iron blocks, now .060 is very common.
Makes for good bench conversation though.
https://ls1tech.com/forums/generatio...92-engine.html
