Cam Swap 5.3
Factory LS3 cam should work just fine. Make sure to note the cam bolt count of both cams. Your 5.3 cam may possibly be a 3 bolt, and the LS3 is likely a 1 bolt. You would need to convert your cam sprocket to a single bolt style. Also, make sure to determine whether or not the 5.3 has VVT.
I would upgrade to the inexpensive "LS6" lifters from GM just to be on the safe side since you are running a 1.8 rocker.
Feel free to give us a call if you have ANY questions.
