Goofy Combo...368ci MUTT
Old Sep 19, 2015 | 10:20 PM
A.R. Shale Targa's Avatar
Pro gear chain connected to custom Comp Cam
Lower end all set waiting for batwing pan
New hyper slugs at exactly zero deck
Old Sep 19, 2015 | 10:31 PM
Few quick updates on my dormant build
Gonna order my T cover soon so I can button up the short block and then I'm a valley cover and head gaskets/bolts from the long block being complete
The Trans is apart and unfortunately needs about a grand of parts which seems surprising since it only ground a little going into second but heck; it is what it is 😟
Money issues will stall this deal longer than anticipated as my wife's employer will be closing by years end 😡
I'm guesstimating I'll need in the vacinity of 3 to 3.5 grand total to finish it up with a new clutch/master; injectors and tune
Kinda sucks but life hits you like that sometimes. The car is paid for and not going anywhere so eventually I'll get to the finish line on this one !!
Old Sep 20, 2015 | 09:42 AM
Know It All's Avatar
That sucks to hear. Looks like an interesting build.
Old Oct 24, 2015 | 08:35 PM
Injector shot at 228cc runner
62cc chambers with hollows
Intake bowl up at injector
Swirl ramp still there but changed a bit
Exhaust bowl out
Old Oct 26, 2015 | 08:22 AM
Decided to double check the machine shop that put the heads together and said "they're fine, springs are good"
Found the intake installed heights at 1.86 and the exhausts at 1.835. Found me some Manley fifty down locks to get the intakes at the Lunati spec of 1.81 and I'll just run the exhausts at 1.785. I'm guessing my open pressures will be similar with .604" intake and .574" exhaust lift
It perhaps would have been fine with the light valves but glad I decided to check it and just make it right
Old Oct 26, 2015 | 09:48 AM
KCS's Avatar
KCS
Moderator
Yeah, I'm not a big fan of just bolting parts on. I have to set it up myself or at least check so I can make a record of it. Depending on the rate of the springs, you probably just increase seat and open pressure by 20-25lbs. I'd say that's a smart move.
Old Oct 26, 2015 | 02:39 PM
GSAWYERS's Avatar
Nice normal money build, interested to find out how it runs. If you aren't stuck on one brand of clutch, I've had great luck with the McLeod RST/RSX twins in everything from 400rwhp dd's to 1000+rwhp cars(past 1k there are better choices). I daily an 05 GTO with a little over 400rwhp and an RST. The car is set up for a wide powerband and good midrange. I have about 25k hard miles on my RST and couldn't be happier with it. Light pedal, good grip and progressive engagement, basically a nice street clutch. I got mine through work on our wholesale account for $650ish. I have a slight resonance at 1800-1900rpm but otherwise it is silent and has never been any problem. It has taken 2+hr long trips at 90+mph, bumper to bumper traffic, been over 160 numerous times, takes hard launches and powershifts like a champ. I wanted the Monster LT1s or a Centerforce Dual Dyad but couldn't pass up the deal I got. In the spring I'll see how it likes a bit more power and a 150 or 200 shot.
Old Nov 8, 2015 | 09:08 PM
Thanks for your interest
Got more time right now than money so I'll look into that particular clutch....Thanks for the suggestion !!
Old Nov 8, 2015 | 09:51 PM
kinglt-1's Avatar
I have heard good things about the RST...might be worth a shot if funds are tight.
Old Nov 22, 2015 | 09:41 AM
Minor update just ordered my new GM timing cover kit from Summit with all the bolts/sensor/harness plug/gasket.....sweet deal for 90 bucks but then I got hooked by the "order 10 more dollars worth of items for free shipping" promp....LOL
Sooooo; that led to the purchase of the knock/cam sensor harness adapter that I will need for the LS1 to LS2 conversion......really neat little set up for another 55 bucks....not bad at all IMO
I just need to remember to re tap the block holes for the larger LS1 knock sensors to relocate
A buddy who owes me some coin from an engine project may be giving me a new LS7 clutch assembly....right in my price range...LOL
I doubt I'll be making much more power than a stock ZO6 any ways so I'm confident it will hold for the few blasts I'll make with it.
I also have another LS buddy with a custom machine job who I'll ask if he could tackle lightening the heavy *** LS7 flywheel before I get it balanced.
If this works out I'll take before and after pics to show what he does. My hope is to shed about 5-7 lbs but that might we wishful thinking.
Lastly I have some header pics of my used XS POWER long tubes......yes China ****....blah blah blah they were marketed as 1 3/4" but are more like 1.75 I.D. since the O.D. measures 1.90"....IIRC RonSSNova also ended up with a set of these bigger tube ones for his 10.99 AFR headed C5
Old Nov 22, 2015 | 09:43 AM
Old Nov 25, 2015 | 09:07 PM
  #32
Old Nov 25, 2015 | 09:08 PM
  #33
Old Nov 25, 2015 | 09:10 PM
  #34
Old Aug 23, 2016 | 12:12 PM
  #35
Dug this one up from the Paleozoic era; Cambrian for you global history buffs
New LS7 clutch kit...✔️
New GM slave cylinder ...✔️
Rebuilt level V Trans from RPM with non ground up second gear and new reverse..✔️
New PAC - 0.050" valve locks to tighten up my installed height on the Lunati duals..✔️
New GM valley cover gasket and PCV 180 deg hose plus v/c port plug ....✔️
New LS2 lifter trays; apparently the new crappy weak ones that suck ....✔️
5 quarts of Royal Purple SynchroMax fluid ...✔️
Expensive. Ouch
Thanks Jeremy
New LS2 T-cover and factory damper on
Self modded factory pump with 25K mi
Pickup tube and upper Bat Wing installed
Old Aug 23, 2016 | 11:47 PM
  #36
Updates from today
Showing the reduced installed height
Drilled/tapped
11/32"drill and M10x1.50
Lower batwing
All snugged up
Factory lifters in the new trays
Perfect 4.020" bore matching LS2 h/g
As she sits with valley cover on (2 bolts missing) and the head bolts yet to be tightened/torqued
Old Aug 24, 2016 | 07:39 AM
  #37
KCS's Avatar
KCS
Moderator
Oh nooooooo, not LS2 trays!!!!
Looking good dude!
Old Aug 24, 2016 | 11:42 AM
  #38
MuhThugga's Avatar
LS2 trayz R gonna 'splode!!!111!!!1!
Old Aug 24, 2016 | 12:30 PM
  #39
Rise of the Phoenix's Avatar
Very nice build. The port work on those heads looks top notch.
Old Aug 24, 2016 | 12:36 PM
  #40
Mavn's Avatar
"I MAID THEESE"
I literally just assembled the EXACT Same shortblock lol same pistons and every thing. ARP Rods with stock Main Studs. Running ported 243's and a holley high ram with a 235/242 .620 .615 cam. Ill let you know on Numbers here in about 2 weeks!! its going in an Auto Envoy Denali
