Oil pressures with "blocked off" DOD engine?
What I said clearly states I would go from the vane style to the georotor like the reg melling and the stock ls6 pump as melling does also make an afm/vvt pump also. I dont know if it is a vane style but I do know the other vvt/afm combo pumps are.
Kurt
"Most NASCAR engines run half the normal oil pressure to reduce parasitic horsepower losses created by the oil pump."
Also said they used a 0w-20 synthetic oil.
http://www.enginebuildermag.com/2012...e-oil-systems/
I know Kurt's "been there done that" with all these LS setups and I'd take his advice over most. But it takes power to make additional pressure. If that additional pressure isn't' needed, why not bypass it?
A good direct comparison on oil pressure VS power gain.
http://www.shoptalkforums.com/viewtopic.php?t=101582
The Nascar guys are running a D1SC maxed out at 10PSI.
The high volume guy is using F3136 and bleeding off excess pressure to maintain 10PSI.
Which one will save HP?
It saves power when you just use enough pump like the Nascar guys or car companies will do. The only reason GM would run the high volume pump is when another function inside the engine requires it, that need forces the added volume. I typically run higher pressure than some others, but I do it with standard pumps and a close eye on clearance. That way my parasitic drag is not increased by the pump volume, just the minor output pressure change. I do sometimes use the high volume pumps, but normally in lower rpm engines.
Kurt
