cam damage
Old May 7, 2014 | 10:16 AM
saccitycorvette's Avatar
LS1Tech Sponsor
Default cam damage
Hey we have a cam that we pulled out of your vette and one of the lobes has some visible scratches from a lifter that was failing. Is this cam trash or is it able to be fixed? Note the scratches are very light and can't be felt when you run your finger nail over them.
__________________
Don't forget to check out our products at www.saccitycorvette.com
https://www.corvetteforum.com/forums...c361808_12.gif
If you like our products, tell others! If not, tell us! https://www.corvetteforum.com/forums...s/thumbsup.gif
Old May 9, 2014 | 01:16 AM
yonerhottlt1's Avatar
You can have it reground but they're gonna have to cut some of the lift off the cam so it'll be a lil smaller depending on how much has to be ground off.
Old May 9, 2014 | 08:05 PM
S10xGN's Avatar
Ahh, no. It would likely be offset-ground to a smaller base circle. Lift can be reduced, increased, or kept the same depending on the base circle diameter...
Old May 14, 2014 | 01:40 PM
LS1Tech Sponsor
Thanks for the info!
__________________
Old May 15, 2014 | 02:44 AM
Hmmm...last time I had a cam reground they cut it from .603/.607 down to .588/.589
Old May 15, 2014 | 09:01 PM
S10xGN's Avatar
Your loss I guess... Kip @ Cammotion just last week reground my core from 0.610"/0.601" to 0.641"/0.624". The LSA stayed the same at 112° but duration went from 233°/245° to 244°/249°.
Old May 19, 2014 | 05:15 PM
Damn, duration went down from 240/245 to 239/244 too. Oh well, good to know for future reference. I'm assuming you just had to run a lil longer pushrod to compensate for the smaller base circle?!
Old May 19, 2014 | 07:03 PM
S10xGN's Avatar
Yup, gotta measure for sure!
