Tearing motor down need help
Old Jul 12, 2014 | 02:02 AM
daltimation's Avatar
Default Tearing motor down need help
Tomorrow I plan on tearing my 5.3 LM7 down to take to the machine shop monday. I have never taken an engine apart that far before. looking for any sort of instruction manual or personal tips. I'm all ears.
Old Jul 12, 2014 | 02:41 AM
lil john's Avatar
ever thing goes... just keep the mains in order....if a ligned centered mains won't matter..
NEW CUT... or blueprting the block..
Old Jul 12, 2014 | 05:36 AM
RezinTexas's Avatar
Take lots of pictures and organize the fasteners. Also be careful not to scratch the crank journals when removing the rods and caps.
Old Jul 12, 2014 | 12:45 PM
74u's Avatar
74u
This! You'll have such an easier time at re-assembly if you know what bolts go where.
Also, keep in mind the factory head bolts & harmonic balance bolt can not be reused. Must replace with new.
Old Jul 12, 2014 | 02:31 PM
Well I've come to the realization that I'm gonna have to bore out the engine a bit and get new pistons. What else should I replace. I plan on boosting 12-15 psi on ethanol.
Old Jul 12, 2014 | 02:46 PM
74u's Avatar
74u
How much do you want to spend?
Forged pistons - $500 - $800
*H-Beam Rods - 6.125" - $550
Clevite rod/Main bearings - $200
Head gaskets - $85-$120
New head bolts (OEM) - $100
Block machining and balancing of rotating assy - $550 - $1100
*Optional...but since you are doing pistons the rods will really be the only "weak link" remaining.
Old Jul 12, 2014 | 03:45 PM
http://www.summitracing.com/parts/wi...make/chevrolet
http://www.summitracing.com/parts/es...2000/overview/
how would these work for my application?
Old Jul 12, 2014 | 05:58 PM
74u's Avatar
74u
Definitely do your homework before you buy and end up with the wrong stuff...speaking from experience here You can paint yourself into a corner real quick.
You will need more information to determine which piston. I would suggest contacting someone like Brian Nutter at Wiseco...he is very knowledgeable. You will need to know what your finished bore is going to be, desired compression ratio, combustion chamber volume, etc. Make sure you have the entire plan locked down before you buy anything.
Who is doing your turbo/sc? Who is specing your cam? Who is tuning it? They should be consulted/involved in picking your combo of parts.
