What do i need for a 6.0 stroker build?
I have a lq4 with a stroker in mind. What Crank should i run? I wanna be able to run pump gas. 402 or 408? Also need help deciding between nitrous or procharger with the stroker.
Good and cheap..
Block machined $1100 Eagle 4in. crank $850 & 6.125 rods $550. pistons are around $750 to $890 bucks...The pistons must match the heads & Boost or Nos... Thats your choice as far as heads...Custom cam to match Boost or Nos.
Nos has cheap start ..But Re-fills
Boost has a high start yet it is Allways on tap.. Your choice again?
