2010 ly6
ok so i picked up an ly6 with 62k for my 83 cutlass going with a 4l80e
pulled heads off motor, cleaned everything up
masts ss cam and spring combo/ comp cams phaser limiter(keeping vvt)
ls7 lifters
holley 302-2 pan
new push rods(bought checker gonna check before purchase
all new gm gaskets , head bolts, crank bolt flywheel spacer etc...
ls3 valley cover
ls3 intake
psi harness
e 38/t42
my question is is there anything else i should do or somthing i am doing wrong ? should i get new actuator for cam? i see everyone using diff head gskets for more compression but i am worried about clearence this is my first ls build i just dont want to get car together and wish i had done somthing different any advice is apprec
ls7 lifters
holley 302-2 pan
ls3 valley cover
ls3 intake
psi harness
e 38/t42
