What Piston for TF GenX255 Heads?
Old Sep 24, 2014 | 08:36 AM
Petey-Pop-383's Avatar
Default What Piston for TF GenX255 Heads?
What Aftermarket Pistons do you need to run with Trick Flow GenX255 Heads?
Will the L92/LS3 pistons work? Or do you need to use a LS7 Piston with the 12° valve angle?
Old Sep 25, 2014 | 11:14 PM
Jimbo1367's Avatar
Depends if you are FI. If NA, I'd think you'd want at LEAST 11.0:1. I believe the angle tips the valve up so you GAIN clearance. Unshrouding the valve.
