LS3 All Motor Dyno Results
Old 10-25-2014, 03:02 PM
cynic783's Avatar
Originally Posted by 82cetuner
did you do any back to back tests from 93 octane and E85? thinking of switching on my 12 to 1 compression ls3. how much timing is actually in it cause with e85 you should be able to jump it up a lot. im at 28 right now
My understanding is that when enough alcohol % is detected in the fuel, timing is added, above and beyond the "high" octane table. I believe it runs 4-6 degrees additional timing, depending upon RPM. I do not know the total timing advance. I will need to bring Dave Steck into the convo this is his territory.
Old 10-27-2014, 07:56 AM
82cetuner's Avatar
I think I could free up some power for sure, btw my setup runs out of power after 6200 or so as well. I have a fast 102/102 setup with speed deinsity and 104 lid so no restrictions. also ported cnc ls3 heads. I wonder if its the ls3 heads themselves holding power back after 6200 to 6300. I have a descent size cam and Im not so sure going bigger will help. it is on a 112 +3 not sure if that takes the rpms down some or not. I would love to see my motor make power to 6700 because it can run 7k all day long
Old 10-29-2014, 02:32 PM
HINSON Motorsports's Avatar
Great looking and sounding car man. I love these ol Pontiacs, especially the G8s and GTOs. I have a GTO and wouldn't trade it for anything.
Old 10-29-2014, 11:58 PM
CAMSTER's Avatar
Hey Man good numbers, I know how you feel about your goal however with the cam you have you did great, in my opinion with the heads you have and 11.5 compression on e85 and your intake system (hoping your cold air intake is not restrictive you could do easy 525 whp.
I would have Camhelp@guerragroup.com spec the cam true their software and change push rods to 3/8 by .082 wall.
You would see a big difference mainly from the cam, have the cam spec for 6,800 shift point 7,400 red line.
Old 11-02-2014, 02:10 PM
Youngblood16's Avatar
Honestly, I believe 82cetuner is on to something. The 250cc runner heads seem a little big for your stock bottem end LS3. Ive seen both Mamo and Tooley 430+ Ci built motors that run no more than 245 runners, and pull 550-600 hp and tq all day. and if its torque you're looking for, aftermarket cathedral ports carry all the torque and its usually a nice flat torque curve.
Old 11-08-2014, 01:47 PM
slowZZZ's Avatar
Love the G8 GXP, walked past one in the parking lot on my way to work.
I wouldn't get too hung up on hitting the magic 500whp, looks like you're managing great passes without it
Old 11-12-2014, 08:49 PM
Grenade19's Avatar
Nice numbers
Old 11-21-2014, 12:15 AM
Detoxx03's Avatar
Assuming this is still a 376 right?
Old 11-22-2014, 08:10 AM
handyandy496's Avatar
A larger cam will certainly pass your goal. If you have easy access to e85 you could tear up the streets with 13.5:1 compression. Right?
Old 11-22-2014, 11:17 AM
CAMSTER's Avatar
I like to add that the cat back solo is got to be of some restriction imo.
Old 12-13-2014, 11:13 AM
Exira's Avatar
6.0 .030 over
l92 heads milled .015
cometic .040 gaskets
btr 226 231
truck intake
ls7 90mm t
flat tops no reliefs
just have open headers on it now
factory air box which is restricting and no underdrive pulley
392 hp 369 tq thru auto trans and transfer case 285 tires stock converter and rear end
Old 12-13-2014, 06:13 PM
  #32
ringram's Avatar
Originally Posted by cynic783
No, I will have to check into that. It's a VCM over-the-radiator type.
Leading hypothesis from my builder is intake restriction.
Ok I reckon thats your issue then. Work out the filter area of the VCM and airflow that it supports and you will find your problem if you ask me.
I had similar issue with an over the radiator, took out the filter and 50rwhp turned up. Now running a large rotofab cone..!
Easy to test just dyno with filter out.
Old 12-16-2014, 01:44 AM
  #33
C5natie's Avatar
Originally Posted by redtan
Hmm would've expected some better numbers out of that setup, and I agree it doesn't seem to be carrying past peak too well.
Those numbers are achievable by a stock headed stock intake LS3 (well maybe not the torque). With a ported FAST and aftermarket Trickflows I thought it would carry the power better.
I have to agree. When i dynoed my cam only LS3 (L92 block and pistons) it did 470/455 and that was with a stock intake, stock LS3 heads, 1 3/4 headers, 10.0cr and 91oct CA gas through a 4L65E. The cam was the 231/236 from Texas Speed.
Old 12-16-2014, 10:02 AM
  #34
luisdavid11's Avatar
my g8 gt, never been dynoed, but i trap the same mph as you at the 1/4 mile. pat g cam stock heads stock intake 2.92 gears and the stock converter with 2.0 60 fts. 12.0 @ 118 so yeah something is up with your car, might want to look into a RCR or Pat G cam. good luck
Old 01-22-2015, 07:19 PM
  #35
cynic783's Avatar
Default UPDATE: 22 Jan 2015
Found an fixed a restriction between the MAF and Cold Air Intake. There was an unnecessary extra coupler partially blocking the MAF screen. Re-tuned and re-dyno'd.
Best of 502/474 SAE
Old 01-22-2015, 10:28 PM
  #36
pannetron's Avatar
Default That looks more like it!
Glad you found a simple solution to your airflow problem! It's likely worth re-tuning if the airflow into the MAF was disturbed by the obstruction.
Old 01-23-2015, 09:16 AM
  #37
cynic783's Avatar
Default PIC of Airflow Restriction
Here is the offending restriction.
Old 01-23-2015, 09:58 AM
  #38
pannetron's Avatar
Attachment 485313
Wow, that's ugly! I'm no expert but from what I do know, tumbling air flow through a MAF will greatly affect the accuracy of its readings. Hopefully your tune was based on a good MAF calibration and removing that restriction got you back to where the tune expected the MAF to be.
Old 01-23-2015, 10:39 AM
  #39
cynic783's Avatar
Had it re-tuned after fixing it. That's where the pickup in power is from.
Old 01-29-2015, 09:51 AM
  #40
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Nice combo.
@ OP, keep working on the drag racing side of things, I'd expect you to run 122-124 MPH now.
My 2010 Camaro with bolt-ons converter and 3.91 gear trapped 115 MPH last year. Unlocked. I just did h/c and expect to go 124 this year.
How much timing can you run on E85? I'm tempted to mess with E85 myself at some point.
Quick Reply: LS3 All Motor Dyno Results
