LSA-block based engine build I'm a newbie on the forum so I'm posting this as kind of an introduction. I'm building an E-Force supercharged LSA-block based motor for a '66 Chevelle. Here's a link to a blog of my progress to date. If I get any thumbs-up, I'll post updates. |
Originally Posted by pannetron
(Post 18493514)
I'm a newbie on the forum so I'm posting this as kind of an introduction. I'm building an E-Force supercharged LSA-block based motor for a '66 Chevelle. Here's a link to a blog of my progress to date. If I get any thumbs-up, I'll post updates. Just a heads up though, the skirts of the pistons may need some clearancing to clear the oil squirters. I used Wiseco pistons and that's what I had to do. When I moved them away from hitting the pistons, they wouldn't clear the rods. Aluminum is like 2.8 grams per cc, so you can remove some material before affecting the balance of the crank if you do run into the same problem with your CP pistons. |
Originally Posted by KCS
(Post 18494541)
Looks like a nice build. Just a heads up though, the skirts of the pistons may need some clearancing to clear the oil squirters. I used Wiseco pistons and that's what I had to do. When I moved them away from hitting the pistons, they wouldn't clear the rods. Aluminum is like 2.8 grams per cc, so you can remove some material before affecting the balance of the crank if you do run into the same problem with your CP pistons. |
You shouldn't touch the pistons, not wise. Modify the oil nozzle for clearance - trim it. |
Bending the oil squirters worked Fortunately the oil squirter tubes are bendable, not brittle. I was able to bend them to clear the pin boss with very little effort. I completely agree about not wanting to touch the pistons! |
Post up some pics and build thread. There is a conversions section on here for that! |
Originally Posted by schnellttz06
(Post 18533017)
You shouldn't touch the pistons, not wise. Modify the oil nozzle for clearance - trim it. The LSA I had to notch the skirts in ended up making over 750whp on pump gas and has seen several TX Mile as well as SCCA autocross events over the last two years. Notching the piston hasn't seemed to have had any noticeable effect on the power or integrity of the engine. |
Moving my build thread... I'm posting my build progress on this thread now: https://ls1tech.com/forums/conversio...l#post18537457 |
© 2024 MH Sub I, LLC dba Internet Brands
