LS7 cam into LS3: retard? 4 or more degrees
I searched but was not able to find anything on this topic, let me know if it has already been discussed.
I'm thinking about the LS7 cam (211/230), into an LS3. I like it that the idle is smooth and its easy on the valvetrain.
But, I see from some dyno graphs that the LS7 loses some low-end power in exchange for some modest gains up top.
Have people tried installing the LS7 cam with ICL down around 118 (Stock ICL is 122, so 118 = 4 degrees advanced) to move the powerband down some in an LS3 engine? Advancing it should in theory help out the low end power.
Thank you.
Thank you.
In a smaller engine it will seem like it's peaky and yes you can gain some low end by advancing the cam a few degrees and increasing compression and thus torque.
