Which cam sensor on cam swap?
Old Nov 16, 2014 | 07:44 PM
Gonzalo Bravo's Avatar
Default Which cam sensor on cam swap?
I installed a Comp Cam 3bolts camshaft on a L92. Swap a LS3 cover and 4X cam gear. But do I need to swap the sensor also or can I use the stock L92's cam sensor (3 wires)???
Engine is not starting
This is the L92 sensor (12591720) that I am using...
Old Nov 19, 2014 | 06:39 PM
is it?
Old Nov 19, 2014 | 07:48 PM
LS1MCSS's Avatar
I would have used an LS2 cover and sensor. I know that setup works.
