cam bearing damage
Old Nov 23, 2014 | 08:30 PM
06vzssthunder's Avatar
Default cam bearing damage
Just noticed there is a little bit of damage on my cam bearing.. no idea what to do with it. the car was running perfect and was no damage to the cam.
Old Nov 23, 2014 | 11:20 PM
Think I might just play it safe and get new cam bearings. Can get them from Texas speed for just under $50 it's says they are for ls1 ls2 ls3 so I guess they would also fit l76?
Old Nov 24, 2014 | 05:05 PM
Jontall's Avatar
I'd replace them. If it's a stock motor you don't need coated Durabond and they will fit a L76. $33.99 https://www.texas-speed.com/c-199-bearings.aspx
Old Nov 24, 2014 | 09:02 PM
basically stock for now with just a dod delete and ls3 cam but plan on building it for forced induction over the next few years.
Old Nov 24, 2014 | 09:10 PM
can i change it while the bottom end is still all together in the car? its just the front cam bearing the rest look fine.
Old Nov 24, 2014 | 10:02 PM
WE TODD DID's Avatar
You did that when you pulled the cam out.
Old Nov 24, 2014 | 10:21 PM
I dont see how since i was very careful and took my time but anyways if i did mistakes happen and i just want to get it sorted.
Old Nov 24, 2014 | 11:13 PM
So does the engine need to come out and be taken apart to change the cam bearing or can it be done while the bottom end is still together?
Old Nov 25, 2014 | 04:01 AM
Jontall's Avatar
I've heard of it being done with the engine installed using dowels to keep the lifters up, but it's probably going to be very hard to do.
Old Nov 25, 2014 | 05:13 AM
lifters are already out.
Old Nov 25, 2014 | 09:19 PM
D9HP's Avatar
Would that bearing pass through GM's inspection process?
No way. I'd replace it without question!
Not worth a camshaft. Not worth metal in your pan.
Old Nov 25, 2014 | 09:39 PM
im going to replace it just need to see if i can find someone that will come to my house to do it if not i will have to buy a engine crane.
