Hot spots = Cracked Sleeves
After about 10 minutes running at or near max power in a race boat it had a loss of oil pressure and I shut it down. Upon disassemble I found the problem with the oil pressure which is unrelated to what I discovered in the cylinders. On 6 out of 8 cylinders I found a very hot spot at the top of the cylinders on the side nearest to the outer edge of the block. Only the front 2 cylinders were not showing this problem. The hot spot was so intense that it cracked all 6 cylinders. This is directly under the minor quench side of the combustion chamber under the spark plug.
I do not have pictures at this time as the block is at the machine shop for repairs. I have seen hot spots between cylinders on siamezed blocks before, but never at the bottom of the cylinder.
I suspect a lean condition or detonation, but I do not know what else could cause this. I don't know if E85 has different burn characteristics that might cause this. Also, the 1/2" deck plate means the cooling water is that much farther from the top and may have contributed to the hot spots due to limited cooling in that area. I find this hard to believe because this is a siameze block and the sleeves between the cylinders have even less access to the water jacket and they were not hot there. As to detonation, I have seen it before and it usually starts near the top of the piston above the intake valve, not at the bottom. Also, the pistons did not show any indication of detonation or vaporized aluminum. The spark plugs did not show a lean condition, but I may not have enough experience with E85 to read them correctly.
Has anyone seen this happen before and know what might have caused it?
MrE
http://www.yellowbullet.com/forum/sh...d.php?t=293680
MrE
