Cam upgrade for an LS3, how different than an LS1?
New to the LS3 and remember when they first came out folks were not quite used to them and cam selection had to be carefully done to make good streetable average power increases. Huge ports, big valves, heavy valve train compared to the LS2 changed cam selection.
What to do or avoid when selecting a camshaft for an LS3?
No reverse grinds? Split? How much? overlap range? etc.
We can help put together a package that will work great for you! Camshaft, springs, pushrods, gasket etc. We can even help mail order tune it if needed!
Give us a call so we can discuss your specific mods & goals. That's truly the best way to make sure we get you exactly the right combo!!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
I did go a little bigger on my cam, but I plan on throwing some heads on here soon. I didn't want to lose too much torque however because I plan on tracking the car. I went with a 232/238 .621/.603 113lsa cam(Cam motion core. Kip is great.) and put down 484/444 to the tires. Over 400wtq just over 2k rpms.
edit: car has 1 7/8 lth, 2.5" stock exhaust, adm intake.
I read the 10 camshaft comparo done by the mags by that is old news already.
Some basic things to do and some not to do. I mean as for as camshaft stuff. Not bolt-on. You know mild is X range of degress, moderate, aggressive, wild,etc.
I could read all the threads here and in the dyno and camaro/c6 section but that would take a year. There must be a distillation of information somewhere.
Makes around the same numbers with this blower cam as LS3 Camaros with a G6X3 cam make on my tuners dyno, and blower cams are typically softer than N/A cams.
But everyone will tell you that "there's no way a cam like this will do good with rectangle port heads, the duration doesn't have a big enough split, and the intake duration is too big." BS!!
.200 .300 .400 .500 .550 .600
Int. 126 184 224 251 256 257
Exh. 108 143 163 176 180 183
Stock LS3 heads
Int. 156 226 276 310 324 332
Exh. 120 158 183 194 199 204
As you can see, the "weak" exhaust side of the LS3 heads matches LS6 heads peak flow at .400 lift...not exactly weak. People get too caught up in the ratio of intake flow/exhaust flow on the ls3 heads, and neglect that fact that they still outflow LS6 exhaust heads significantly.
LS6 head flow numbers taken from LS1tech Sticky thread
LS3 head flow numbers taken from Lingenfelter (Were more conservative than 3 others charts I saw)
Here's what the collective resources are showing so far:
The bigger L92 numbers for 400+ CID motors seem to favor an intake valve closing point of 50-52 degrees ABDC at .050" (just like a cathedral-port motor).
The L92 motors like around 4 degrees more ignition timing than cathedral port motors. If you're running less than 30 degrees of timing, you're probably leaving power on the table.
The L92 motors respond well to higher DCR as long as it does not limit total ignition timing (see above). Better to have full timing and lower DCR than high DCR and low ignition timing.
The 400+ CID L92s seem to be more exhaust sensitive. 1 7/8" headers seem to help more than on cathedral port motors.
The L92 402s don't seem to not like much more than 15 degrees of overlap at .050" (which baffles the hell out of me). Start making more overlap than 15 and they really start to get lazy down low.
I think with the large intake port, the airspeed must be pretty slow. This might explain why they're so overlap sensitive. This does not mean you have to run a wide LSA cam or a narrow one, you just have to hit the valve events that fit the critical criteria (IVC and overlap).
