Building lsx 427 from l92 block
1. Can I use a stock ls7 pistons and rings for ? If not what size Pistons and rods do I need?
2. Will it be cheaper to get a full complete rotating assembly or buying individual parts?
3. How much does a machine shop usually charge to bore, hone , balancing ect ect?
Thanks
I may be wrong but I believe you'll need a 4.100 stroke for a 427ci motor.
I wouldn't do more than a 4.000 stroke with a motor that's go see a lot of street miles. The 4.000 stroke will keep the pistons in your sleeves better than a 4.100 stroke that would pull the piston out the bottom of the bore further. Sure cubes are fun but they not EVERYTHING..... A good set of heads with a great cam to match is what you really need to help dial in your horsepower goals.
Thanks
We can make your L92 a 427 LS7 it will make between 590-620RWHP on motor.
You can make 550-575(camshaft/compression dependent) with a 416 with our CNC L92's.
1. The LS7 piston and ring would fit if you Sleeve the block. LS7 4.125"
We run max bore at 4.070" on LS3's.
2. It is always best to have a professional shop assemble something like this. Your talking about making 700+ HP
3. Depends on the shops level of equipment and knowledge.
We specialize in what you are looking for.
Turn your LS2/LS3 into a Stage III LS7-LSX
Here is an example of a recent customer build taking a LS2 block and sleeving it to push the bore to 4.130. This package allows an LS2 car to be morphed into a pumped up LS7 and still retain the compatibility with the stock LS2 base engine.
This package is based around a custom sleeved LS2 block that Livernois Motorsports machines in house on its own 4-Axis CNC machine. This allows absolute precision and ensures the block is held to within just +/- .0001 to the specification.
Once the block machine work is done we utilize our own custom rotating assembly, complete with forged H-beam connected rods, forged custom pistons, stainless steel top ring and napier second, upgraded thick wall wristpin and forged stroker crankshaft. This takes us to a 429 cubic inch size.
The shortlock is then complimented with LSX-LS7 heads utilizing our own custom CNC program and valvejob, along with the FAST composite intake. This package is designed for the ultimate in streetable performance from a large cubic inch LS base. The added cubic inches and breathing from the bigger bore, coupled with the longer stroke and high flowing cylinder head matched with custom camshaft really turn this engine into a beast.
Shortblock, Longblock and Complete engine packages just like this are available to retrofit your LS2 and LS3 equipped car into a big-bore stroker LS7 monster with direct bolt-in capability.
Take a look at this earlier post it has some images
https://ls1tech.com/forums/general-l...i-ls7-lsx.html
Thanks
That's a good buy there!! I just wouldn't use nothing at all from Eagle....
I already have the short block. I'm talking any getting the rotating assemblies ect ect and machine work.
BTW....the 427ci LS3 long block, built to my specs that's going into my SS was built by Texas Speed. They're a real classy outfit!
KW
Lmk how much you ended up spending at the machine shop.
As far as the other post with a 4.125 crank and a 4.070 piston...thats not a 427. That is larger.
There are many reasons the aftermarket LS pistons have a .927 pin. Can anyone guess them?
The stock pin on an ls piston (besides ls9) is .944-.945. Nearly every aftermarket pin set for any stroker build is a .927. Some of that is due to rod and pin availability and ease of availability of parts and manufacturing. And some of it is due to pin placement and ring pack placement. The CH on the can be the same on 2 pistons but if one has a .945 pin and one has a .927 pin, the .927 pin piston can have more available material for piston strength and more room for a ring pack without bridging the pin hole and having to use support rails. That is extremely oversimplifying it of course but that is a short explanation.
There are so many builds out there that ARENT on tech or cf. Not everything gets put on the internet either.
