Titanium LS7 valve spring retainers with 1.959" height
The issue is the LS1, LS2, LS3, and LS6 family use a 1.800” installed height and the LS7 use 1.959” installed height. Part of the height difference is the longer LS7 valves, but a substantial portion of it is in the retainer. The photo shows an LS3 titanium retainer on top and an LS7 OEM retainer on the bottom. Both retainers are on identical OEM LS7 valves.
Does anyone manufacture an LS7 titanium retainer for the 1.959" install height, or even something close?
Are you trying to shave a few grams off the retainer and keep the stock springs?
Yes, I'd like to use the 1515 spring with a lighter retainer.
Thanks Brian
Seeking an update on the Ti retainer for the "stock" install height. I'm also running the PSI1515 with stock steel retainer.
Been able to spin her to 7250RPMs with no signs of valve float wit stock Ti intake valve and Ferrera F2042P hollow stem. Ill love to save a few grams!
Rapid prototype in hand, samples coming soon.
