Knocking from the top of the motor
Old Mar 13, 2015 | 02:37 AM
08turboZ71's Avatar
Default Knocking from the top of the motor
I have a loud knocking noise coming from the top of the motor. Pulled the heads and changed lifters and it didn't help. This is a fresh rebuild and ran good the first few start ups. Has everything new, Ls9 cam and valve springs. You can take the #1 intake rocker off and don't have the noise. If you cut fire to that cylinder, it still knocks only stops if you remove the rocker. Took a video of how it sounds.
Old Mar 13, 2015 | 08:07 AM
Gotit4cheap16's Avatar
Sounds like a bad rocker to me. Mines recently developed a knock as well but can't figure it out.....
Old Mar 13, 2015 | 12:13 PM
08turboZ71's Avatar
I did change the rocker and had the same results.
Old Mar 16, 2015 | 09:20 AM
my bandit's Avatar
I'm very interested to see the outcome of this. I'm dealing with what I think could be the same issue (I'll try to post a video soon also) but everything checked out on my car also. Mines a constant knock like a spun rod bearing but its definitely a top end knock.
Old Mar 28, 2015 | 10:42 PM
08turboZ71's Avatar
Ended up being 6 wrong rod bolts. But it really sounded like a top end knock. Running good now
Old Apr 1, 2015 | 10:04 AM
74u's Avatar
74u
Thanks for coming back and posting the final resolution
But...what does that mean? Wrong rod bolt?
Weird that removing a certain rocker arm eliminated a noise downstairs
