Cam bearing replacement with rotating assembly installed?
This is the Cam bearing at the back of the block
one of the bearings in the middle of the block
bearing at the front of the block
If the block needs decking, then you have to take it apart anyway.
Then, what is your goal for this motor. How long do you want it to live? From the looks of it, it has had a pretty long service life already (looks like it was run hot). How are the cylinders (crosshatch)? Any ridge at the top?
It may be easier and less expensive to rebuild it now than after it tosses a rod out the side.
