Should I be concerned? Ported LS7 heads..
I'm pretty much at a loss on how someone would even go about "fixing" it. Obviously no sort of epoxies would hold up to the heat. Welding doesn't seem like an option, as I'm guessing that much heat next to the valve guide probably isn't good. There's a tiny bit of oil there but I don't see any smoke out the exhaust... Thoughts? Should I even sweat it?
Thanks,
Ryan
Clean the port and take another pic.
If there is damage you can talk to a cylinder repair shop and see what they say.
Last pic is way better. Just an oil trail. No worries, but I'll be happy to lap the valves in and check the guide clearances, etc.
