L92 engine with LS3 intake - high crankcase vacuum
The L92 only has ports on both valve covers, not on the valley. The LS3 intake manifold has one port right after the throttle body which I have hooked to the passenger side valve cover. The driver's side valve cover was blocked off but I tried running it open just to test and still tons of vaccum.
This engine has new rings which are not broken in yet & a hone job, new 230/236 cam & cam bearings, new lifters & pushrods, reused main & rod bearings, only gaskets reused were the valley cover & intake manifold because they looked brand new.
So what's going on here? How can I fix this? When I put my oil cap back on my oil pressure drops. My MAP at idle is 48-50kpa.
Is the motor running rite only vacuum area is the intake manifold.
I think your oil pick up tube is socking both air and oil so check see if you left the O ring out from the connection of your pick up tube to the oil pump.
Check see if oil pick up tube is cracked or broken somewhere, cause the only pump you have inside the motor is the oil pump, she is only suppose to pick up oil.
