need help with l92 cam?
Old Apr 15, 2015 | 09:25 PM
mannyls1m6's Avatar
Default need help with l92 cam?
I have a l92 engine with ls3 intake manifold. I am going to install some lt headers. And it is going in a f-body. It has 5364 heads stock. I am going to do a vvt delete. And wanted to know what would be a good cam to install on this daily driver.
Old Apr 16, 2015 | 01:07 AM
low2001gmc's Avatar
MASS seller approved
I love my lunati 232 238, 599 601, 113+4. With that lift, it is easy on the springs and is very strong...
Old Nov 28, 2016 | 06:59 AM
5'5 Big Bob's Avatar
Do the heads have to come off or can you run the dials in the block to hold the lifters up?
Old Nov 28, 2016 | 10:53 AM
pantera_efi's Avatar
Default Spring Color = ?
Hi, there are some LS-3 springs, yellow, that will be good for .560" lift.
There are blue springs, steel color springs, those require lower lift.
When you state "no head R&R" do you plan to retain the original springs ?
The GM "advice" states to "spin" the cam, one turn, pushing ALL the lifters to max lift, then cam removal is possible.
I never have tried this though I believe it's possible.
I would regrind your VVT cam, install limiters, use MY VVT controller.
I use Crower to do this with my lobe masters, would you like this ($200.00) option ?
I have "frozen" the VVT motor with no problem found in BAJA race engines, another option.
My ECU-882C has built VVT in control, as yet another option.
What EMS will you use ?
Lance
