aluminum 5.3l bearing clearance
Doing a turbo lh6 forged rods pistons street strip motor 10.5 compression fully ported 862 heads tsp e85 fuel 19-22 lbs of boost twin turbo what main bearing clearance should i have my machinest set up the block for? Max 6900 rpm usually 67-6800 dont want oil pressure to tank on cruises
What would you consider not enough idle psi? You plan to run yours harder than I do, so the larger clearance's are probably in order but I just got an ERL 427 running that started life as an aluminum 5.3. According to the build sheet the mains are at .0018-.0019, using the Melling 10296 with the red spring shimmed "a little" I have to run 20/50 to carry 30psi hot idle pressure, idle speed is 750. It will live for years like this, I know that, but I would prefer it to be 35-40. It just makes me feel better to see a little more than that. The same pump in the iron 6.0 that it replaced did over 40 hot idle with 10/30 and 100 less rpm. The aluminum motors definitely open up more warm, about .0010 from everything I've read. This is in my daily driver, something I plan on using for years and not opening up every couple years.
You have to have a oil cooler.
If you had erl doing the engine I would go with what they recommend they build a bunch of them.
Having enough oil pump is key. All oil gets thin with heat. Alum block will gain more main clearance that. Iron. I would not worry about 20 psi at idle.
Tim
Tim
Moderator
For builds like this, I like to use coated bearings. I'll use a bearing that may normally give me .0025"-.0030" or so, and then have PolyDyn here in Houston coat the bearings. Clearance will be about .0015"-.0020" with the coating. Oil pressure will be good and if something bad happens, the coating is wiped away and the bearings will still be undamaged.
