ls2 c6 228r boltons
Old Apr 30, 2015 | 06:24 AM
lsxTAlemy's Avatar
Default ls2 c6 228r boltons
just got an 06 c6 ls2 a6 just hit 80k. future plans im looking in to getting ls3 heads and pro charger d or f 1 but that's no time soon. nitrous is for the time being awaiting the pro charger. im going with the 228r cam stock heads and 100-150 shot to have some fun for now. im NOT trying to to blow it up.
i have already done tsp 1 7/8 long tubes 3' orx and custom x back with dyno max mufflers k&n filter that's how she sits now. just swapped in 228 r cam this weekend. street tuned on monday.
what have you guys hit these things with? safely with cam and stock fuel pump. injectors at 85%
nos plate kit, mini progressive controller, fuel press safety switch. im thinking the lcn2000 from lingenfelther for timming and window switch.
still have stock intake man and intake wit k&n drop in. is it worth it getting and air aid kit now with a cam. what bolt on's em i missing ? ud pulley worth it??
car runs strong just looking to see if something could be holding me back?
Old Apr 30, 2015 | 06:51 AM
redbird555's Avatar
I would absolutely look into a new intake and cai. I bet theres 25 hp sitting there alone with the cam. As far as now I can see 390-395whp but with a fast and cai I can easily see 420
Old Apr 30, 2015 | 09:57 AM
lsxTAlemy's Avatar
tune is at 28* and 12.8 afr was humid as hell that day too. last two degrees made a big difference in the performance of the car.
was thinking about ported ls2 intake and ordering an air raid cold air this week..
Old Apr 30, 2015 | 10:44 AM
HCI2000SS's Avatar
Do yourself a favor and scrap that ported LS2 intake idea and just buy a good used Fast intake
Old Apr 30, 2015 | 10:50 AM
05LS2C6's Avatar
What Cam Specs?
Old Apr 30, 2015 | 11:20 AM
lsxTAlemy's Avatar
seen so many things about fast only making slight power over the ported ls2.
Originally Posted by 05LS2C6
What Cam Specs?
228/228 588/588 @112lsa
Old Apr 30, 2015 | 11:32 AM
HCI2000SS's Avatar
Yes I've read a few things stating that as well, but if you dig a bit deeper you will see that the Fast dominates...maybe not always with impressive peak dyno numbers but with track applications and so on
Old Apr 30, 2015 | 12:06 PM
05LS2C6's Avatar
at .588 lift what do your heads flow? I have heard the heads flow well up to .600 lift, maybe a set of rockers would be better
Adding more air into the intake will only help if your heads are starving or lacking the charge.
If this info below is correct, then you wont gain much
Casting Number 243
Head: 2001 LS6 5.7 Liter Passenger Car
Material: Aluminum
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
Old Apr 30, 2015 | 12:28 PM
lsxTAlemy's Avatar
got it thank you 90 92 0r 102 id think the 102 is over kill right ?
Casting Number 243
Material: Aluminum
Part Number:
12564243
everything seems about right just on the ls2 is at 11:1 compression.
im currently running the stock intake with k&n's. the radiator cover has been pulled out and now the stock box looks awkward. so im looking for cai.
im running the cam on a single spring i don't want to push it. I'm pretty happy with the gains. just looking to well match up the combo. later on ill get the 3200 stall but im not ready to bring down the rear. i do everything my self and the rear would be a pitta working on jack stands.
Old Apr 30, 2015 | 01:22 PM
HCI2000SS's Avatar
The 102 is definitely not overkill at all. I used to think that as well. Evidence has firmly shown the 102 to be a better performer in every application
Old Apr 30, 2015 | 02:05 PM
lsxTAlemy's Avatar
will the 102 accept the stock tb till time to swap to a 102 ?
Old Apr 30, 2015 | 02:07 PM
05LS2C6's Avatar
yes the stock TB will fit on a FAST, and you can port your TB too or PEAK will swap your TB for a ported TB
Old May 2, 2015 | 07:27 AM
lsxTAlemy's Avatar
thank you ! im going to get the air aid and zr1 spoiler and start putting to the side for the fast ...
i'm just scared of investing on a fast and a lil nitrous back fire blow it to Pisces...
Old May 2, 2015 | 07:39 AM
lsxTAlemy's Avatar
you put the rockers on my mind the rocker will increase lift on the set up but will it put more strain on the springs? im thinking it would. i have comp single spring 600 lift i believe...
Old May 2, 2015 | 09:29 AM
A.R. Shale Targa's Avatar
I would already be running the Lunati dual or BTR spring kit on there as those cam lobes will tax the limits of a beehive and you seem concerned about it.......you certainly want to avoid this....on such a beautiful car
Old May 2, 2015 | 10:06 PM
redbird555's Avatar
Casting Number 243
Material: Aluminum
Part Number:
12564243
I assume you're talking about 1.8 rockers, in which case thats a very bad idea. The 228r is ground on xer lobes which are pretty violent lobes in terms of beating up springs and lifters. Adding a 1.8 rocker is going to make that worse. A 243 head is all done at .600 stock so .588 lift on the cam upped to over .600 with the 1.8 wont do much at all.
Also porting the ls2 will still cost 200 or more and then you'll still need to get a retune anyway. For a few hundred more you can get into a fast that will still handily out perform an ls2 even ported. The ls2 just isnt that great of a design all around. The gains from a fast dont come from just increased airflow but more so from the more efficient runner design. With my stock 243's I consistantly pulled vaccuum at wot in my car with my ls6 intake which is known to flow more than an ls2, a fast will always gain power over a gm intake with cathedral heads.
With your setup I could easily see a fast picking up 15-18hp seeing as they normally pick u 10-15 over an ls6 and the ls2 is worse than that. The 90/92 fasts are good but the 102 will make more power, has various runner options if you ever want to swap them out and its built better.
Old May 4, 2015 | 07:37 AM
lsxTAlemy's Avatar
yes i know i have heard plenty of things about it but most of the stories was on the on the older springs witch had problems.. the car made a very good change and in happy with it. I'm just looking to see if i left anything on the table with the stock stuff. i have herd the intakes and stuff on these cars flow pretty well at stock form. but sense i added the cam i was looking to see what could hold me back.
thanks for the info im going to get the cai air aid kit and the zr1 spoiler and ill looking for a 102 .
Old May 12, 2015 | 05:23 AM
lsxTAlemy's Avatar
Default new heads
i have a set of 317 heads sitting there. will it be worth it to shave em and port them? ill be adding dual springs and studs...
Old May 12, 2015 | 05:39 AM
HCI2000SS's Avatar
Since you already have them it's worth it IMO. Of course there are better options but since you already have them in your possession why not
Old May 12, 2015 | 07:13 AM
lsxTAlemy's Avatar
came off my old build. i was thinking if they could be made just as good as the 243's? they should be identical other than the combustion chambers... will i run in to issues milling them to get 11 11.5 to 1 ? i know there's issues with milling them for the 5.7 to get them that high in compression...
