3 bolt cam gears.
Old May 16, 2015 | 09:18 PM
Mt.Dew's Avatar
Default 3 bolt cam gears.
Are the 3 different types " phased" differently?
Example.... Type b .. Dot to dot will set the cam straight up. While, type c ... Dot to dot will retard the cam 8 degrees.
Anybody?
This is an LC9 in question.
Old May 17, 2015 | 08:11 AM
CAMSTER's Avatar
Default Cam Gear....
Contact Brian Tooley he will tell you what you need and sell it as well.
http://www.briantooleyracing.com/
Or Texas speed.
http://www.texas-speed.com/
Old May 17, 2015 | 09:09 AM
Mt.Dew's Avatar
Not really the answer I'm looking for. Thanks
Old May 17, 2015 | 10:09 AM
KCS's Avatar
KCS
Moderator
Anybody?
I'm about 99% sure they're all the same.
The VVT stuff, on the other hand is like that. Not to mention there were two different cam cores which were also phased differently. I'm pretty sure LC9's had VVT though, at least mine did.
