LS2 NO oil Pressure?!!?!!!?!!
Old Jun 9, 2015 | 12:40 AM
CoBy Williams's Avatar
Originally Posted by CAMSTER
When the oil filter is removed if you crank the motor it should gush oil out immediately true the filter threaded stud which is like hollow pipe with threads outside for the filter, no need to start it until you know there's oil lubricating that poppy.
You are right. I probably shouldnt attempt to start it until i know it will build oil pressure. im surprised I havent already messed something up because of the many times as ive turned it over to see would i see oil up top or coming from the filter area. But i did pour a little oil on each side of the heads before i attempted to turn it over.
