Complete Gasket Kit?
Old Jun 9, 2015 | 09:38 PM
my bandit's Avatar
Default Complete Gasket Kit?
I am rebuilding my L76 from the ground up and I'm wondering if there is somewhere I can buy a complete GM rebuild gasket set from or if I have to purchase them all independently.
Old Jun 10, 2015 | 12:37 PM
KCS's Avatar
KCS
Moderator
Try giving TSP, or any of our sponsors a call. You probably won't find a "complete" kit, but you should be able to find most of what you need in some of the kits offered and pick up the remainder with a little help from the sales departments.
Old Jun 11, 2015 | 09:46 AM
doc350's Avatar
Yeah, TSP sells an "Engine Rebuild" gasket set that includes pretty much everything you need. Plus you have the option of upgraded pieces (ie, ARP bolts, Cometic gaskets.)
Old Jun 16, 2015 | 09:15 PM
my bandit's Avatar
So far I have this list for a complete engine rebuild
Description - Part # - Quantity
Oil Restrictor - 12573460 - 1
Water pump Gasket - 12630223 - 2
Rear main seal - 89060436 - 1
Front crank seal - 12585673 - 1
Oil pan gasket - 12612350 - 1
Rear cover gasket - 12639249 - 1
Front cover gasket - 12633904 - 1
Head gasket - 12610046 - 2
Valley cover gasket - 12610141 - 1
Valve Cover gasket - 12637683 - 2
Am I missing anything else? Would you go with GM over BTR brand gaskets? The total is about $150 difference between the entire set.
