Short block for boost?
Old Jun 18, 2015 | 01:30 AM
62nalide's Avatar
Default Short block for boost?
Idk if this is the right section or not but I decided to go boost on my tank, going to be running an x275 88mm. What C.I. and C.R.?
My thoughts were 370-388ci iron block. Goal is to hit single digits in the 1/4
Old Jun 18, 2015 | 06:19 AM
1sick_eg's Avatar
Do you have a budget in mind for the short block? The ERL superdecks are awesome blocks, but are around 7k for everything. If I were using the stock longblock, I wouldn't go higher than a 416, but you should be able to hit 9's even on the stock bore and stroke. Since I think you're still staying solid roller, I say stick with the stock stroke and rev her out. As far as the block goes, like I said, you should be able to hit 9's on the stock sleeves no problem, but an iron or sleeved block will help you sleep at night.
Old Jun 18, 2015 | 06:20 AM
1sick_eg's Avatar
If it makes you feel better, I've considered boost as well. It's never fast enough. Definitely getting out of my original build intention now.
Old Jun 18, 2015 | 07:28 AM
FLYZNTN's Avatar
377 stock LS3 block all forged internals at 10 to 1 compression. Add some methanol and you can get in the 9s and drive the car every day to work and back IMO.
Old Jun 18, 2015 | 08:47 AM
LIMITLESS92's Avatar
Stock 4.8 block on 20#'s should get you single digits for at least one pass
Old Jun 18, 2015 | 09:38 AM
cmac06's Avatar
There's no one way to do it. If just 1/4 passes are your delight, the iron is the least expensive. Stock crank with forged rods and Pistons, 10:1 compression. I like my ERL block, personally, though.
Old Jun 18, 2015 | 09:55 AM
62nalide's Avatar
Here's what I'm using
Old Jun 18, 2015 | 09:56 AM
62nalide's Avatar
 Michael S. Palmer
Old Jun 18, 2015 | 10:47 AM
gnx7's Avatar
You don't need a stroker crank to run 9's with an 88mm turbo.... but for longevity a forged one is probably a smart idea.
Basic K1 or Compstar crank/rods and forged pistons are all you need. The next limitation is the clamping force of the heads.... while stock thin deck casting heads can get it done (LS3/L92 or even 317's).... an aftermarket thicker deck head is better to stop deck surface deflection/warping.
Old Jun 19, 2015 | 02:05 AM
62nalide's Avatar
Thinking of doing an lq4 tov start off if not a built/forged 388ci
Old Jun 19, 2015 | 06:16 AM
FLYZNTN's Avatar
4.060 Bore x 3.75 Stroke I'm guessing.....
