Oil pressure problem
As I'm cranking, not seeing any oil pressure or oil to the rockers. The lines are plumbed from the rear port of the engine (to the oiling system) and to the outlet on the filter relo bracket. The forward port on the engine (return to filter) is plumbed to the input on filter relo bracket, with my oil pressure sender plumbed in between.
When I first plumbed it up, I poured oil into the lines, then used compressed air to start moving it through the motor. When I started getting assembly lube out of the rockers I stopped.
If I disconnect the line from the outlet on the filter relo and crank, it easily pumps a large quantity of oil, so the pump/pickup is working.
What am I missing?
Thanks,
Charlie
I'm hoping the remote sender with the separate lines for in/out helps with a way to pinpoint.
Charlie
Thanks,
Charlie
