L92 vs Turbo L33
at first it was between turbo l33 and ls2
l33 won for power goals for the price, plus if i didnt want to turbo it right away
i could still have a little fun with a cam etc
but now looking at L92's and how its pretty much an ls3 with a few differences
I was wondering if it could match that similar budget turbo build of the l33
If im aiming for around 500whp
assuming i can get a full L33 for $1000
and an L92 Long Block for $2000 (Id need different intake, oil pan and stuff anyway)
Also would want to look at the weight difference
I couldnt find anything on how much a full L92 Weighs
Peak numbers don't dictate whether or not a car is going to be or feel faster than another. For example, this is a 405 WHP dyno chart I pulled from a Google search looking at RB25 dynos:
Here is a 414 WHP dyno chart for a LS1:
While the peak numbers are only within 9 HP of each other, look at the curves and the torque numbers under that curve. At 3,000 RPMs, the RB25 is making about 140 ft/lbs of torque, whereas the LS1 is making about 330 ft/lbs. That is a huge difference, especially when you are putting that motor in something light like a RX-7.
