7.425 pushrods? Is my math right?
Old Jun 29, 2015 | 02:55 PM
moneypit94's Avatar
Default 7.425 pushrods? Is my math right?
New fti (comp) cam, a set of stock heads I sent to tea, trick flow large bore multilayer head gaskets, and comp cam truion kit.
Used a comp cam 6.800 adjustable push rod. Was exactly 11 turns for intake and just under 11 1/8 turns for exhaust for 0 lash.
Does 7.425 sound right? Was expecting to maybe go shorter and not longer.
Old Jun 29, 2015 | 03:20 PM
dw456post's Avatar
Isn't the comp pushrod checker .050 per turn? 11 x .050 =.550 + 6.80= 7.35
Add the 1/8th turn is .006, so = 7.356 is what I get.
And add in the preload of .050 and I get a 7.406----looks like you used .069 preload, which I'm sure is OK.
Old Jun 29, 2015 | 03:24 PM
Atomic's Avatar
I need a gauge for that
1 turn is 0.050", right?
Intake: 6.8+11*.05=7.35 then 0.050" preload for 7.4
Exhaust: 6.8 +11.125*.05=7.356 + 0.05" = 7.406
Obviously adjust if you want something different than 0.050" preload.
Old Jun 29, 2015 | 04:02 PM
moneypit94's Avatar
I did .070 for preload. That's what I kept reading was proper preload for ls2?
Old Jun 29, 2015 | 06:14 PM
moneypit94's Avatar
If .070 is not the recommended preload for the ls2 motor please let me know.
Old Jun 30, 2015 | 07:25 AM
MuhThugga's Avatar
Instead of counting turns, just buy 8" digital calipers and measure the length of the checker.
As for preload, .070" - .080" should be the goal with factory lifters.
Old Jun 30, 2015 | 07:39 AM
slow trap's Avatar
the comp cams usually have a smaller base circle so slightly longer p-rods are required. not enough preload and you have that sewing machine sound. unfortunately alittle to long and valves may hang open or a collapsed lifter. the 7.425 should be perfect imo.
Old Jun 30, 2015 | 04:28 PM
Gray86hatch's Avatar
Measure the actual length. Counting turns is asking for problems.
Tim
Old Jul 4, 2015 | 04:14 AM
moneypit94's Avatar
I have a seen a few people on here saying to actually measure the pushrod or pushrod checker. Unless you are using a specially designed tool to measure pushrods that will not be accurate. Pushrod length is not based off the end of one side to the end of the other. I have heard you can get away with that by subtracting .025 and be fairly close, but that becomes a guessing game.
Old Jul 8, 2015 | 12:25 PM
gagliano7's Avatar
I measured an old 7.4 pushrod so I would know how much the actual length is. Then I did the same with the checker to get my numbers. If I remember correctly the 7.4 came out to 7.418.
Old Jul 28, 2015 | 09:31 PM
sabersaw30's Avatar
My valvetrain liked less preload on the ls7 lifters 10.5 turns on pushrod checker put me at 7.375 with .050 preload.Anything over .070 and mine was real noisy. I think the ls7 lifters like lower preload then higher.
