What will my compression ratio be? 416 LS3
New LS3 block
6.125 forged rods & 4 inch crank
4.070 Wisecos, -3cc flat tops w/ valve reliefs, pistons actually have a slight dome to them to offset the valve reliefs, K464X7
cometic 4.080 head gaskets, .040 thick
GM GMPP CNC LS3 heads, 68 cc chambers
http://www.ebay.com/itm/Wiseco-K464X7-Piston-Kit-Chevy-LS-3cc-Dome-4-070-Bore-fit-Chevrolet-All-/311238766405?hash=item487746af45&vxp=mtrPiston listing says 11.4:1 w/ 68 cc chamber but it doesn't say what gasket is used to achieve that.
http://www.csgnetwork.com/compcalc.html
I used the ECR calculator & I come up with 11.57:1, but I have no clue what the piston deck clearance is as the short block isn't together. So I put .005 for clearance & that's what I came up with. I am trying to keep the CR at 11.5:1 & thought for sure I'd have to mill these heads but looks like I wont?
Thoughts? Thanks
BTR .660 lift duals w/ titanium retainers
Btw, the cam I'm looking at is pretty much exactly that. But as a Low Lash Solid Roller... 248/262 .705/.688 113+4... it works out to 243/257 113+4 .695/.678 with the lash taken out. If you can control the valve, it'll make power very high into the range.
. Mine has 22 degrees of overlap.....
