LSX block for a 440 build.
It's $2,795 shipped from Jegs. Anywhere has it for better? Considering it for a 440 build. 4.185 bore on a 4.000 stroke nitrous motor. LS7 heads. Looking for all out 7,000 - 7,300 peak HP RPM in a jet boat. That's why short stroke big bore.
not-a-sponsor
If you want to roll the dice, sounds like this is a machined block that would normally be assembled into a crate motor but sold bare, its decked and bored... honed too? Run the main bolts, leave the main/cam as is. 4.185 sounds like it may have a finish hone in the cylinders (for whatever type of rings they use in LSX.... moly?)
Pound in the cam bearings and assemble it.
Hellfire type rings are more universal on cylinder finish than moly or steel.
You can get a "junk yard" aluminum block and have it sleeved for about 2k or so.
RED quoted me just under 2k to sleeve my LS7 block.
have a look, a little more than $2000.00
R.E.D. website, I couldn't find any prices but $2000.00 is what he quoted me to
but he doesn't do the final hone to fit the pistons, thats why I went with ERL, save some
on somebody else to finish hone to fit pistons.
$3650 for the 6 bolt option. LSX is over $1000 cheaper. I know it's about 150# heavier, but I personally couldn't make myself spend the extra money on it.
Not knocking it, I've considered a wet sleeve block myself, but understand the costs involved.
But seriously, Steve at RED supplied me with a brand new 5.3 GEN4 truck block and fitted MID wet liners for $3,200, so I think if you sent him a second hand 5.3 truck block he would sleeve it out to 4.185" for around $2K. Why don't you just call him up and talk to him yourself, I find him a pleasure to do business with.
Wet sleeve changes this by creating a its own structure within the cylinder block. To install them into an LS2 or 3 block the sleeves and aluminum material will all be bored out and liner will be installed into the main saddle of the cylinder block. This liner/sleeve will be surrounded by coolant in most scenarios. Diesel blocks are typically like this and, top fuel etc. The liner or sleeve is fully replaceable and is generally thicker iron because it doesn't have the cast in structure of the factory aluminum block. It's wet because of the coolant surrounding the iron cylinder sleeve.
