Water dripping from a spark plug, LS1
Old Jul 18, 2015 | 06:49 AM
LS1TA76's Avatar
Default Water dripping from a spark plug, LS1
Soo today while changing my spark plugs, number 2 cylinder spark plug was full of water .. it was even dripping water all over the place. So is it just a cracked head gasket that leaking water inside the cylinder or could be something worse?
P.s: the engine starts fine and runs fine at low rpm but cuts off at full throttle
Thanks
Old Jul 18, 2015 | 08:57 AM
xBoostx's Avatar
Are you using power adders, overheating?
Old Jul 18, 2015 | 09:15 AM
LS1TA76's Avatar
Power adders yes.. its a carburated Ls1 with a 650 cfm edlebrock and hi-rise intake, Comp cam (forgot the numbers). And set of high compression ls2 ported heads (10:1).
Overheating? Yes eventually when the coolent level drops.
Old Jul 18, 2015 | 01:37 PM
KW Baraka's Avatar
Originally Posted by LS1TA76
Soo today while changing my spark plugs, number 2 cylinder spark plug was full of water......So is it just a cracked head gasket that leaking water inside the cylinder or could be something worse.......
Blown head gasket if you're 'lucky' .....
Cracked block if you're not .
KW
Old Jul 18, 2015 | 01:42 PM
LS1TA76's Avatar
KW
You sir just caused my new nightmare..
Thanks btw.. hope its only the gasket
Will know when as soon as i get the time to get my heads off
Old Jul 18, 2015 | 02:23 PM
RixTrix's Avatar
Intake leak? that is an end cylinder.
Old Jul 18, 2015 | 03:15 PM
KW Baraka's Avatar
AFAIK, water doesn't run through the intake.
KW
Old Jul 18, 2015 | 03:18 PM
LS1TA76's Avatar
Water gose to the block without passing through the intake. In ford small blocks yes it gose through the intake first.
Old Jul 18, 2015 | 05:34 PM
xBoostx's Avatar
How much juice you may have lifted the head, the area of the spark plugs is at the center of the cylinder and where the head is weakest due to meet way point between bolts and the spark plug hole itself helps in the weakening of the area.
Once the head lifts will continue to leak till you change the gasket only problem is it will continue to lift so lets just hope it didn't.
