Better motor combo?
LS3 block with GMPP LS3 heads and LS3 intake
LS2 block with either PRC as cast or AI 232 heads and FAST 102 intake
Both will be cammed similarly with the only variance being about the heads themselves.
Would one or the other block make for a broader and more power, or am I splitting hairs here?
I'd probably do the LS2 block with the As-Cast heads, FAST 102, and a Solid Roller.
The PRCs do have a little bit more airflow and now come with lightweight valves, will that make a decent difference in power and/or ability to run 7000rpm or is that enough for the AI heads?
I still would do the LLSR though. That will add more power than a swap of heads.
Heads drain back the oil a little better in Road Racing situations
Versus LS3s, read about that in the CF road race section. Research and invest
In your oil system, lot you can do before dry -sump to improve
Reliability/Longevity.
