Fix for this?
Old Jul 27, 2015 | 12:51 PM
DrX's Avatar
DrX
Default Fix for this?
What's the cause fix for this? All 8 pistons/cylinders on both top and bottom sides. LSX block.
Old Jul 27, 2015 | 09:15 PM
LLLosingit's Avatar
How many miles on it before tear down? What is the bore/stroke?
There could be a few things that cause this but it's not uncommon on a stroker engine.
Old Jul 27, 2015 | 09:27 PM
LLLosingit's Avatar
I guess I could try to give you more answers. Many stroke/bore combinations actually pull the piston slightly out of the bore add that to the fact that pistons are clearanced for the crankshaft and or short skirt can leave a lot to be desired when in comes to keeping the piston from rocking in the bore= causing accelerated piston skirt/bore wear. Pistons to wall clearance can also cause this but due to thermal expansion of the piston there is only so much you can do.
Old Jul 27, 2015 | 09:41 PM
DrX's Avatar
DrX
Thanks. 2000 miles. LSX block. 4.0 stroke, 4.125 bore IIRC. PB clearance .005" PD blowers 20 PSI. Shift 6500-7000. See teardown thread below.
Old Jul 28, 2015 | 11:49 AM
DrX's Avatar
DrX
After cleaning up a few piston tops, it looks like detonation has been occurring. Is this the typical skirt pattern seen from detonation? Possible lubrication or clearance issue? Cooling issue?
Old Jul 28, 2015 | 03:16 PM
KCS's Avatar
KCS
Moderator
Rub your finger along the bottom of the cylinders. Does it feel sharp or like it was deburred?
Old Jul 28, 2015 | 03:35 PM
DrX's Avatar
DrX
This how it is finished:
Old Jul 29, 2015 | 07:50 PM
DrX's Avatar
DrX
Cylinders measure pretty round and straight at 4.1275 +/- .0005 with the +/- being at the bottoms. Measured in 4 directions at 3 depths.
Piston skirts all measure 4.125 at widest dimensions. Land diameter is 4.084.
So I get .00125 for PB clearance?? (4.1275 - 4.125) / 2
Or is it just calculated as bore diameter - piston diameter? In that case it would be .0025
 Michael S. Palmer
Old Jul 30, 2015 | 02:43 AM
KCS's Avatar
KCS
Moderator
The piston-wall clearance is just like bearing clearance; ID minus OD.
With a torque plate bolted on, the taper in the cylinders might go away.
Old Jul 30, 2015 | 02:45 AM
KCS's Avatar
KCS
Moderator
That looks sharp. It's probably where you're getting your skirt wear from. I deburr the bottom of the cylinders with a sandpaper cartridge roll and it ends up nice and smooth.
Old Jul 30, 2015 | 08:15 AM
DrX's Avatar
DrX
Still tight at .0025" ?
On both the bore and counterbore edges?
Old Jul 30, 2015 | 09:49 AM
helicoil's Avatar
Little large, not a big deal, and not the problem
Ideally, all the way around the bottom of the bore. It is most critical on the thrust side. This is often neglected, very critical step, especially on strokers.
Old Jul 30, 2015 | 09:51 AM
helicoil's Avatar
Just break the corner with the cartridge roll, it is hard to do it too much
Old Jul 30, 2015 | 10:00 AM
KCS's Avatar
KCS
Moderator
Depends. For a 4032 alloy, it's probably just right but since it's a power adder I'd assume it's 2618, which would be tight. I'm also assuming you're properly using a dial bore gauge and micrometer accurate to .0001" as well.
Old Jul 30, 2015 | 02:59 PM
DrX's Avatar
DrX
I think it is probably correct at .005 PB, but I was reading the bore gauge(.0005) wrong. What threw me off was I used a dial caliper at the top of the bore as a sanity check and it was telling me it was under 4.130. Now it looks like that caliper reads around .002 under actual.
